Off-Road Forums & Discussion Groups - View Single Post - the noise is back!!
post #9 of (permalink) Old 12-30-2001, 10:55 PM
TiminMb
Re: the noise is back!!
I had to replace my crank pulley because it was worn out and the belt was now touching the bottom of the V. That meant that no matter how much I tightened the belt (hard on the bearings!) the belt had not traction, as it's the sides of the belt that make proper contact. Anyhows, I swapped the drive pulley from a spare motor and never had a problem since. It was always worse in the cold or if snow got sucked in thru the radiator.
Tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
