Off-Road Forums & Discussion Groups - View Single Post - Steering Column Question
post #4 of (permalink) Old 03-20-2000, 10:49 PM
Re: Steering Column Question
To get the column apart there are about 3 or 4 bolts coming through from the backside. I ran into the samething on mine. I dont know if I can tell you everything from memery or not. Best I remember the keyswitch has to come out, the rod to the dimmer switch has to be disconnected, of course the steering wheel has to be removed. You will just have to kinda feel your way through it but the bolts (screws) come through where it looks like the column is joined together. If you just need to your signal lights switch you just have to remove the steering wheel. If you need to the wiperswitch then you have to remove the whole column.It isnt too bad a job. You have to have the steering wheel lockplate tool though. I am sorry I cant remember the details better but it has been a while since I did that. I hope this will help you. Good luck.
