Re: engine temperature
I'm not sure about the S-10s but my Cherokee's Rochester 2SE choke has an electric heater on it. The connector came loose and the 2.8 would run rough and rich after start up on cold mornings. The choke plate would not open fully. I put the connector on the coil blade and squeezed it down good with pliers. It runs better now. Also make sure that your heat stove tubing is connected at the air cleaner and exhaust manifold and the air intake flapper valve works. That would also make this little engine run better in cold weather after start up.[img]/wwwthreads_images/icons/smile.gif[/img]
BTW, Good Luck with that rebuilt carb, Tim! [img]/wwwthreads_images/icons/smile.gif[/img]
