Re: Will 302 swap in 6 cylinder Bronco?
The motor mounts are different. The 6cyl mounts right into the cross member while the 302 mounts to brackets that bolt onto the back of the crossmember. You can get the V8 mounts from the dealer and they just bolt in.
Did it go together nice and easy? You did something wrong.Will have to do it again.[img]/wwwthreads_images/icons/crazy.gif[/img]
DaveC
