Off-Road Forums & Discussion Groups - View Single Post - yj starts then stalls
post #3 of (permalink) Old 09-23-2001, 11:28 PM
Re: yj starts then stalls
ss287,
You need to check if you have any engine code(s), then you can troubleshoot from there. When was the last time you clean your idle air sensor (on the side of the throttle body)? It probably is full of carbon build up. You need to have Torx drivers to remove the unit, you might want to clean your throttle body while you at it (you'll need to have a new replacement throttle body gasket).
My 91 Jeep stalled at the light when it was cold, I cleaned my idle air sensor and worked for few weeks (no codes). Just last month, it did the same thing. Except this time I got a code for throttle position sensor, so I just replace TPS and it has been trouble free so far.
Nycjeep88 [img]/wwwthreads_images/icons/cool.gif[/img][img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/wink.gif[/img]
Let's go baja in NYC and see how well your suspension holds up.... [img]/wwwthreads_images/icons/smile.gif[/img]
