Off-Road Forums & Discussion Groups - View Single Post - Anybody have a power brake booster bracket?
post #8 of (permalink) Old 09-21-2001, 11:00 AM
TiminMb
Re: Anybody have a power brake booster bracket?
Yes, the Gm booster will fit the 84 CJ7 bracket, it's slightly wider bolt spacing so you need to file the holes a bit wider. Your stock master cylinder will bolt on to the booster as well. The tricky part is that the booster from the gm I used (S10 truck or cadillac) has too long a linkage fromthe booster to the bellcrank. You have to cut the linkage down. Best not to weld it in place on the booster as you could damage internals. Many do it that way though. I had a shop rebuild the booster and install a shorter linkage. Cost me $150.00 cdn and then it just bolted right on to my 84 CJ7. Very good upgrade.
Tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
