Off-Road Forums & Discussion Groups - View Single Post - Anybody have a power brake booster bracket?
post #7 of (permalink) Old 09-21-2001, 10:33 AM
ChrisM
Re: Anybody have a power brake booster bracket?
I am not sure if it will fit a stock CJ bracket. I had to drill out the holes on the YJ bracket to 1/2" and it fit with just that slight amount of modification. I suspect you will have to do the same with the CJ bracket.
The brake lines are the same fittings. But the location (where the lines screw in) on the master is reversed.
Also, the vette master is for disc brakes all around. You will need to add a 10lb residual valve in line if you have drums in the rear. you can see the one I have in the first pic. It is the little red thing that is in line. I intend in going to discs in the rear which is why I went with the vette master.
'79 CJ-7
ChrisM is offline
