Off-Road Forums & Discussion Groups - View Single Post - Anybody have a power brake booster bracket?
post #5 of (permalink) Old 09-20-2001, 10:08 PM
ChrisM
Re: Anybody have a power brake booster bracket?
Yep it is in a straight line. I am not sure how it would fit in a stock CJ with a steel tub. Mine has a glass tub which has about a 1" body lift built in. So it clears easily. Without the bellcrank (or YJ bracket) the dual diaphram booster looks like it would be a tight fit with the steering column and shaft but might work. The booster and master from an '82 corvette. The vett booster has a threaded push rod instead of a loop at the end. This allows you to easily make an adjustable rod to change pedal height.
Here is a shot from the front.
'79 CJ-7
ChrisM is offline
