Off-Road Forums & Discussion Groups - View Single Post - No start !!! HELLLPP !!!!!!!! anyone????!!!!!!!!
post #4 of (permalink) Old 09-16-2001, 04:07 PM
jeepgod
jeepgod's Avatar
Re: No start !!! HELLLPP !!!!!!!! anyone????!!!!!!!!
well.. you said it turns over with direct jump.. then you have a bad solenoid.. or something screwy with your wiring..
your blue wire going to the solenoid is coming from your ignition switch.. it should splice into the blue wire from the ignition module.. and it should go to the "s" post on the solenoid.. the "i" side should be some kind of red resistance wire.. that should go to the "+" side of coil.. and to the red wire on the ignition module..
the green wire from the module goes to the "-" side of coil..
during start your "s" should have 10-12 volts on it.. for cranking the engine over.. when in the run position you will have 2-4 volts on the "i" side.. that is what the resistor is for..
another thing.. make sure ALL your connections are clean.. and tight.. also make sure the solenoid is grounded.. (bolting it to the metal fender is ground)
http://www.jeepgod.net
jeepgod is offline
