Off-Road Forums & Discussion Groups - View Single Post - engine shuts off when winching
post #8 of (permalink) Old 09-09-2001, 04:08 PM
GP'n
Re: engine shuts off when winching
I also agree with the wiring or current draw problem. You should be able to idle and operate the winch under load at idle. You may have a weak winch motor or bad alternator, (I know you had it checked out). But you may have a bad ground causing some or most of the problem. The winch needs to be grounded directly to the bat and the + should come directly from the batt. all connection at the batt should be clean and TIGHT. This goes for all connections in conjunction with the charging, starting, and winching operation.
GP'n
GP'n is offline
