Off-Road Forums & Discussion Groups - View Single Post - Tj tcase linkage problems
post #2 of (permalink) Old 09-07-2001, 09:36 AM
kerryp
Re: Tj tcase linkage problems
Sounds like he is either too far away from the T-case now becasue of the body lift, or his shifter may be moving far enough to get into low but hitting the tub and not fully engaging. I would take off the console and take a look. If its hitting, maybe he can trim a bit so it will fully engage, or if the linkage is too short because of the lift, maybe he can make a piece that is longer? These are just shots in the dark,,,,, hopefully gives him some place to start... [img]/wwwthreads_images/icons/smile.gif[/img] good luck and please let us know how he finally fixes it so we will have the info if we ever need it. Aftr did the lift on my TJ, I couldn't get it to even go into 4wd, the shifter wouldn't move, before I had a chance to really look into it, I apparently went down my bumpy road enough times which apparently jarred it loose, it must have been in a temporary bind, its worked great ever since.
http://bastroptx4x4.alloffroad.com
kerryp is offline
