Off-Road Forums & Discussion Groups - View Single Post - Front Dash Removal How?
post #6 of (permalink) Old 09-06-2001, 08:56 PM
Re: Front Dash Removal How?
CrowHorse wrote:
>>Loosening the steering column will allow the 4way flasher
>>switch to clear.....
Absolutely. There's two M8 bolts right under/behind the steering's column plastic "cowl". U will need Torx (don't remember the #) bit and a ratchet extension. May be tight....it's usually Loctite'd.
Once you remove those two buggers, the steering column drops down just enough so u can remove the steering column switch block (four screws and two electr. plugs), and then instrument cluster and then dashboard. Fairly easy I'd say (compare to pulling dashes off other vehicles :-).
Oh yeah, remove the steering wheel prior to all this...[img]/wwwthreads_images/icons/smile.gif[/img]
Hope it helps
[img]/wwwthreads_images/icons/smile.gif[/img]<font color=red>marc</font color=red>[img]/wwwthreads_images/icons/smile.gif[/img]
<font color=blue>I wish I was smarter. I'd be wheelin' now :-)</font color=blue>
