Off-Road Forums & Discussion Groups - View Single Post - Answer to Fuel Injection Test!
post #4 of (permalink) Old 09-05-2001, 05:20 PM
brendan
Re: Test Yourself on Fuel Injection!
How many ramps? If just the front axle is on ramps, did the pint of fuel in the tank slosh back away from the pickup? Start with the simple solutions, right LEVE?
Is the fuel system vapor locked? Problem could be solved without $.10 by properly aligning fuel filter.
You mean Crankshaft Position Sensor(CPS), not Throttle position Sensor(tps), right? Does the howell system even use one? I thought that sensor was only necessary in a multiport setup.
Brendan
Proud owner of the world's best running Carter BBD
