Re: Almost ready - SOA Q\'s?
Well, if you have a CV rear it's not that hard:
Line up the drive shaft so that there is no angle (or as close to it as you can get) on the rear u joint - ie: the rear yoke should be pointed directly at the tranfer case output.
If you don't have a CV then you need an angle finder.
The front I just made parellell with the existing SUA mounts. That way the castor blah blah blah was the same as before.
It wasn't that hard.
All the rest of the stuff you can sort out later.
If I remember correctly you already got all the steering stuff sorted out, right?
Chad Lloyd 95 YJ 4.0 NP435 203 EBD20 woodies D44s 4.88 detroits SOA cross over 35 X 15.5 SXs 8274
