Re: Almost ready - SOA Q\'s?
go for it. it is a realatively simple project. just watch you pinion angle alon wiotht the castor angle and you'll be alright. you will need to address shocks in the future to handle all your added flex and also a track bar to take care of axle wrap. YOU WILL NEED ONE!!!!!! check and double check to make sure they are centered under the jeep. it is easy to mess up if you are not careful. they make rear stainless steel brake lines. are you using drums or disc's? the only other thing i can think of is drive shafts. some people need to have them lengthend and some don't. you'll just have to see.good luck.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
vortec350/4L80E/d300/d60fr/14br/detroits/4.56/38's
