Off-Road Forums & Discussion Groups - View Single Post - Wiring the starter solenoid
post #5 of (permalink) Old 09-04-2001, 11:03 PM
sandfox
Re: Wiring the starter solenoid
its like leve said it doesnt matter what side. run the cable from the battery to one of the large terminals also connect the other wires that are pulling power there also . now on the other bid stud hook only the cable running down to the starter . then with a test light on one of the small wires going to the small posts see which one lights up when you turn the ign switch in the crank position hook that one up to one of the little posts and try it if it doesnt work try the other small post ( thats if you have 2 small posts and 2 big posts on your blower motor run a jumper from the positive batt post directly to the blower motor terminal and see if the motor runs if it does its either in the fuse or switch or wiring shouldnt be to hard to track that down hope this helps ..... dave
gotta play in the sand
sandfox is offline
