Off-Road Forums & Discussion Groups - View Single Post - Tub removal - no idea what to expect.
post #4 of (permalink) Old 10-07-1999, 11:19 AM
LooseNut
LooseNut's Avatar
Re: Tub removal - no idea what to expect.
You'll have a lot of rusty bolts to contend with. An angle grinder helps to cut them off. Disconnect the clutch linkage, master cylinder, steering column,wires to the back-up lamp switch on the transmission.....I'm sure there's something I forgot. If you don't remove the shifter, you'll have to lift the body up over it.
Loose nut behind the wheel
Another right-wing conservative.....
LooseNut is offline
