Off-Road Forums & Discussion Groups - View Single Post - drive shaft
Thread: drive shaft
post #2 of (permalink) Old 10-06-1999, 08:18 PM
Re: drive shaft
When you installed your lift, your driveline angle most likely changed. Installing shims between the leaf springs and axle to tilt the pinion up or down (may have to experiment) can alleviate this (you may not be able to get rid of it totally).
The angle at the transfer case should match the angle at the pinion and they will cancel each other out, if not you get a vibration.
