Off-Road Forums & Discussion Groups - View Single Post - why cant i get these bolts out of my frame??!
post #10 of (permalink) Old 08-07-2001, 08:02 AM
LEVE
Re: why cant i get these bolts out of my frame??!
This is a case of the nuts rust bonding to the bolts. As the nuts are welded in they're there to stay.
I've been successful drilling a re-tapping using a good varriable speed drill and lots of sharp carbide and tungston bits. I start by grinding the area flat and using a center punch to mark the center of the bolt material so the drill doesn't wander. Then I drill with a 1/16" pilot hole, and progressively use a 1/8", 5/64", etc., untill I can slowly re-tap the new hole. Then I use LOTS and LOTS of anti-sieze compound on the bolt as it's inserted. Between that and the oil I throw in the frame each year, the new inserted bolts slide out slicker 'n snot.
