Off-Road Forums & Discussion Groups - View Single Post - Does anybody know the size of stock YJ Dash Guages?
post #5 of (permalink) Old 10-06-1999, 11:34 AM
Jeepskate
Re: Does anybody know the size of stock YJ Dash Guages?
You'd use the standard 2"+ gauges for the cluster and standard 3"+ guages for the speedo & tach...you'll want to pull out your factory speedo & tach and take a look at the mounting for them. You'll notice that there are metal mounting tabs attched to the bodies and you'll need to duplicate this setup. A bit more info on the cluster: when you pull it out and take it apart you'll end up with the white case which holds the cicuit board, a black fascia which has the holes cut into it that makes it look like you've got individual gauges, and a clear cover. You'll want to gut the white case, glue the gauges to the back-side of the fascia, then re-assemble the package and bolt it back in the dash.
Jeepskate is offline
