Off-Road Forums & Discussion Groups - View Single Post - Not the low crawl ratio t-18
post #3 of (permalink) Old 10-04-1999, 10:21 PM
Re: Not the low crawl ratio t-18
Probably the least expensive thing you can do is find a Ford T-18 from a 2WD truck. You then disassemble
both it an your Jeep T-18. You reassemble all of the Ford parts except the mainshaft, use the Jeep mainshaft,
into your Jeep case. Voila, you have a 6.32:1 Jeep T-18!
You could also use the Ford case and tap it to mount the tranny-tcase adapter. Use the same internals as for the
Jeep case. This might make mounting the tranny to your bellhousing easier as the Jeep T-18 uses a unique bolt
pattern, but the Ford T-18 is the same as the T-150.
I've got a Ford-cased T-18 built this way (actually used Scout T-18 mainshaft and adapter) waiting to go in my CJ.
Jim Kyser
[email protected]
1946 Willys CJ-2A
