Off-Road Forums & Discussion Groups - View Single Post - early cherokee questions
post #2 of (permalink) Old 10-07-1999, 01:58 PM
Tim
Tim's Avatar
Re: early cherokee questions
The 360 AMC is a good motor, only weakness is oil pump gears are in the timing cover and wears with high mileage causing the oil pressure to drop. TH-400 tranny is bullet-proof. Q-trac is a good xfer, just need to replace the chain every 60-70,000 miles and keep the special oil in the case. It can be converted to part-time with Mile Marker kit and then use ATF instead of Q-trac oil. I'd not get the kit with 16% overdrive as it raises your gearing, (lowers numerically), and will not be beneficial for towing the Jeepster. The kit w/o o.d. doesn't come with a chain, so if you need one, it's extra. Dana 44's front and rear are great. I can't remember if '74 had electronic ignition. If not, you might want to update. Great rig. Most mechanical stuff interchanges with the Waggie.
Tim Bothwell
'66 Jeepster Commando
'70 Wagoneer
'76 Wagoneer-sold
Tim is offline
