Off-Road Forums & Discussion Groups - View Single Post - New winch = TJ Running Hot
post #7 of (permalink) Old 07-09-2001, 07:14 PM
Re: New winch = TJ Running Hot
I went to the 180 deg. thermostat and that cured my problem in my cj. But if what pontiac58 said is corect then your stuck. But there is a racing coolant that I know of named Evans that has a rediculasly high boiling point, something like 300 deg. and prevents the air pockets from forming in the coolant around your combustion chambers, which causes cracks in your head. It doesn't actually lower your operaqting temp., but allows you to run much higher temps. It comes already mixed, and I think it's quite expensive. I don't know if this info will help you or not but thought I'd pass it on.....
Shannon
78cj5 4.2
t176,dana300
