Off-Road Forums & Discussion Groups - View Single Post - My Clutch linkage fell apart on me!
post #4 of (permalink) Old 07-09-2001, 12:29 PM
Pigpen
Re: My Clutch linkage fell apart on me!
Sounds like a combo of issues. There is a small clip on either end of the bellcrank that keep the bushings in place and let the bellcrank float left and right as needed. The bellcrack should not fall out. Check your engine and tranny mounts as suggested above. If you have had any type of body lift the increased distance can also cause issues. I have had to lower the bracket on my body to try and keep the bellcrank parrell to the bracket on the bellhousing.
Pigpen
76 CJ5 360/T18A/Bronco gear D20/D30 big brake disc, locker/D44 big drum working on disc/ factory slip/4inch lift/33's/6000lb winch/All Fiberglass/electric fan/full cage/ appetite for MUD
Pigpen is offline
