Off-Road Forums & Discussion Groups - View Single Post - Ooops! Need bigger tires ?!?
post #4 of (permalink) Old 07-08-2001, 05:15 PM Thread Starter
kutyafal
kutyafal's Avatar
Re: Ooops! Need bigger tires ?!?
Since it's a new rear axle I just rotated it to point at the tcase yoke, -2 deg. The driveline will be at 20 deg. I'm actually counting on a little spring sag. The rc D30 front will also go SOA soon. I'm a little worried about using a CV rear shaft with an offset pumpkin (compound angles). Sorry, the bumper/tire carrier is home made. Check my web page if interested. As for getting it out of the garge I hope if I get the tires down to 3 psi I'll loose a few inches. If not then I have to disconnect the rear shackles and let it sit on the springs while backing out. Ouchh!! [img]/wwwthreads_images/icons/shocked.gif[/img]
'91 YJ,I-6,2.5" lift,33s,D30,D35c,Lock-Rights F&R, SOA and Ford 8.8 soon http://members.home.net/t.molnar
kutyafal is offline
