Off-Road Forums & Discussion Groups - View Single Post - Oil pressure sending unit?????
post #7 of (permalink) Old 07-06-2001, 12:28 PM
jeepgod
jeepgod's Avatar
Re: Oil pressure sending unit?????
an accessory spot in your fuse block will also work.. they are usually only 12v when key is on and start.. get a little electrical light tester.. about 4 bucks.. and clip it to ground.. and stick the pointie end in the acc open spot in your fuse block.. you should have atleast one.. unless you put something else there already..
you can also use the guage.. wire.. the other wire will go to ground..
http://www.jeepgod.net
jeepgod is offline
