Off-Road Forums & Discussion Groups - View Single Post - Oil pressure sending unit?????
post #3 of (permalink) Old 07-06-2001, 08:12 AM
jeepnmatt
Re: Oil pressure sending unit?????
on either the AMC 258 or AMC V-8s, the oil pressure gauge sending units are on the passenger side. on the I-6, its behind the distributor. on the V-8's, its on the side of the block behind the front aluminum cover. i assume you are trying to wire your fuel pump into a oil pressure switch so that if you lose oil pressure (roll-over), fuel shuts off. i think you will need an oil pressure "switch" instead of a sensor. hopefully someone else has done this and can help you out. matt
jeepnmatt is offline
