Re: compression test ??
squirt oil in the cylinder-it pressure goes up suspect the
rings-if it stays pretty much the same suspect valves-don't
rule out a head gasket tho but usualy they go bad between
two cylinders causing 2 low readings--oldzuki
88 spoa samurai/weber/isky
97 sidekick sport
those that can samurai those that can't ?
