Off-Road Forums & Discussion Groups - View Single Post - 86 G/W WITH AMC 20
post #5 of (permalink) Old 06-19-2001, 12:52 PM
Sycho15
Re: 86 G/W WITH AMC 20
The 727 is the better of the two, just barely. It is a bit stronger (although I doubt you'd ever break either) and a bit shorter (though with your long wheelbase this is a moot point). It is much more efficient though! This results in better response and mileage, and generally cooler operating temps (which leads to longer life). You can bolt more transfer-cases to it without any special adapters. I beleive any Jeep x-case used from 1980 will bolt on, with the notable exception of the pre-90 NP207 and NP231s used behind manual transmissions (they have a 21-spline input shaft instead of 23-spline. You can swap in a later 23-spline shaft for the NP231 'case). The J-Truck x-case from the 80s, the NP-208, is also interchangeable and a nice way to get a part-time 'case under your rig. If you ever want to swap to a passenger-side-drop front axle, a Dana 300 will also bolt up.
This tranny was used in TONS of Chrysler and AMC vehichles and has many aftermarket parts and rebuild kits for it. Swapping a MOPAR engine (like a 318 or 360) should be pretty easy with this transmission. A MOPAR bellhousing and appropriate flexplate and torque converter can be swapped onto it. These parts are fairly cheap and easy to find in a junkyard.
They are both easy and cheap to rebuild. Get a video tape with the kit and use simple hand tools. The first time may take you an afternoon while an expirienced person may do it in an hour.
Sycho15 is offline
