Off-Road Forums & Discussion Groups - View Single Post - Running A Little Warm
post #2 of (permalink) Old 05-29-2001, 07:39 AM
Re: Running A Little Warm
you mention electrical tape on your wires. do you have connectors of some kind on there or are you just twisting the wires together? If you have not upgraded any of the wiring on your clod i would recommend that. i'm running dean's plugs on all my connections and have upgraded to dean's " wet noodle " wire. super flexable and great wire. I have run 2000 batteries with no problem, but i have not run a 4400. Are you using stock pinion gears? If you have gone to a higher gear, that could be your problem too. If none of this helps, write back and we'll try something else.
