help! won't run rite
535 views 7 replies 4 participants last post by  ppillard
G
help! won\'t run rite
I FIXED IT, I FIXED IT, I HAD 2 PROBLEMS #1 THE CARB WAS JUNK, # 2 I WAS USING A ECM FOR AN AC EQUPPED ZOOK ON A NON A/C CARB AND IT REAllY FREAKS IT OUT.. ........ SOLUTION REPLACE CARB WITH SPARE AND REPLACEED ECM WITH PROPER SPARE. AND IT RUNS GREEEEAT !!!!! THANKS FOR ALL THE INPUT THOUGH, P.S. YOU BETTER WATCH OUT NOW PILLARD! NOW I DON'T HAVE TO IDLE UP THE HILLS.
#2 ·
Re: help! won\'t run rite
It could be an electrical problem. Tim from NCO had a similar problem which turned out to be the distributor. Check the connections to the distributor, especially the ground wire. Hope this helps.....
All Good Medicine,
Crow
G
#7 ·
HEY PILLARD AT LEAST WHEN I GO THERE IS ALWAYS SOMETHING ON TOP OF THE HILLS FOR YOU TO HOOK YOUR WINCH TO. I'D HATE FOR YOU TO HAVE TO STAY AT THE BOTTOM WITH THE JEEPERS.
