Off-Road Forums & Discussion Groups - View Single Post - carter bbd idle tubes
post #2 of (permalink) Old 09-28-1999, 10:48 PM
Re: carter bbd idle tubes
It's actually pretty easy. First check it out by looking down the carb with the engine idling, if there is a problem with the tubes, u will see a slow dripping from the venturi. Then, Remove choke plate, look down carb, and remove screw holding down venturi, pull venturi straight up, and clean tubes real good with carb cleaner and wire. Re-install, and start her up.
