Off-Road Forums & Discussion Groups - View Single Post - Lockright install in amc 20: c-clips?
post #3 of (permalink) Old 04-21-2001, 11:41 PM
Re: Lockright install in amc 20: c-clips?
thanks ozark...
i have 3.54's for gears, and the retaining pin for the pinion shaft is accessible with the ring attached to the carrier. so i guess i can do the istall with the carrier in the housing.
are there any tricks to removing the axles? i bought the Jeep with moser 1 piece axles in it, so the chiltons and haynes write-ups are not too useful. i am assuming you need to take all the brake stuff off, and then remove the 4 bolts behind the brake shoes, and then the axle should slide out?
JUSTIN
http://www.geocities.com/jeepboyjus
83 CJ7 258 T5/D300 4"lift locked AMC20 1pc axles 3.54
