Re: yj body on cj frame
Stalled in the middle of a similar project.Only one set of mounts does not line up,the ones right in front of the rear wheels.Have to relocate fuel filler tube,I guess most guys just spin the tank 180 degrees.I cut the filler hole in the cj location and covered the yj hole with diamond plate.Body mount bolts are different size also,so make sure you get the body bushing/lift for the body you are using.
My name is Glen......and I am a........Jeepaholic.
