Re: Space in an EB
The guy that had the Bronco the same size as the CJ must have been talking about one of the little toy models. I have and 72 EB and it swallows my best friends CJ. The back bed is approx 4'x4' and you can fit the bench seat of an S10 in the front with 5" to spare at each door. If you are looking for room the Bronco would definitely be an option. You will have tons of seating options including almaost any junkyard high bach seat and sliding and reclining seats. My best friend is 6'2, 275lbs and has to squeeze himself into his CJ-5. That's even afte he put on the 12" Grant steering wheel. He easily sits in my Bronco without having to slide the seat completely back. As for the Scout, I've been in a few and they are slightly larger than the Bronco, but this will tell on you when you get into some tight trails. Good Luck.
