Off-Road Forums & Discussion Groups - View Single Post - Dual alternators/Underhood welder idea??
post #3 of (permalink) Old 03-12-2001, 11:33 AM
Re: Dual alternators/Underhood welder idea??
Leve, how could you have seperate circuits on the same battery? You'd have to parallel the alternators! (Which wouldn't work, right?
If you wanted to have one alternator be your alternator, and the other be your welder, you could do that...just pull the voltage regulator on the welding alternator, put a switch on the 12v "input", and a wire your welding leads to the case (-) and to the positive output terminal (+)...that would work without blowing up the first alterntor, wouldn't it?
Moneyless, Will weld for jeep accessories.
