Off-Road Forums & Discussion Groups - View Single Post - Changed engine, now got clutch problem
post #10 of (permalink) Old 03-11-2001, 08:26 PM
yjdave
Re: Changed engine, now got clutch problem
when you bled the system, did you remove the slave cylinder from the bellhousing and push the rod in, or just bleed it hooked up? if you dont remove it to push it all the way in, you could pour a bathtub full of fluid thru it without getting all the air out. check that.. i was thinking of the standard hydraulic setup, not the concentric bearing.
paw print
yjdave is offline
