Re: Changed engine, now got clutch problem
The pedal feels normal and the clutch disengages, just not completely. I jacked up one rear wheel. With engine running and clutch pedal pressed, the wheel turns. If I shut it down,put it into reverse & restart it - - the wheel turns backward.
I can hold the wheel from turning with my hand while someone starts the Jeep and holds the clutch pedal in. If I let go it turns again.
Lowrange
Email:
[email protected]
87 Wrangler, 4.2L, Weber carb., HEI, AX-15, Procomp 2 1/2" lift, Procomp 3000's, Superwinch
