Off-Road Forums & Discussion Groups - View Single Post - need the pros on this one!
post #6 of (permalink) Old 03-26-2000, 11:45 AM
sas87yj
Re: need the pros on this one!
well i took apart the carb and cleaned out the idle pickup tubes. they didn't appear to be clogged. to access these tubes you have to remove the choke plate and the venturi cluster. i then removed the air horn and the needle seat assembly. the float now comes out and there was some grime and grains of sand under both float. cleaned all and blew out with compressor. put all back together with same gaskets. runs good again! hope it is resolved!
thanks guys for your input!
keep on keepin' on
steve
