Re: Clutch Shims
You can use three shims with out any problem with the spring bottoming out. Put the shims toward the motor, on the right side of the spring. HPE makes a high engagement orange spring $17.85. You can also notch the weights for higher engagement. I would recommend have somebody who knows how to do it help you. GOOD LUCK
