Re: Clutch Shims
you said a heavier spring, they have an engaugement pressure and compressed pressure and rate. did you check the engaugement pressure? this is what counts,and you want to keep the compressed pressure at or near factory if your not going to change weights. i wouldn't go any more than 2 shimms,you weaken the spring too quick if you go more.
motor head
