Off-Road Forums & Discussion Groups - View Single Post - Jetting
Thread: Jetting
post #2 of (permalink) Old 12-23-2000, 08:04 PM
retiredpop
Re: Jetting
If it fouls plugs that quickly are you sure it's the jets? How is the oil consumption? If it is too high then that could be your problem. Generally if you are able to ride the thing without bogging real bad you can't be too far off on your jetting. In any case if you do decide to rejet I would stick to single size reductions. Jets are not expensive so don't worry about it breaking you. They are only 2 or 3 dollars apiece. Watch your plug color and piston wash when you are jetting down because that can get real expensive in a hurry if you go too lean. Generally the engine light won't come on before you burn it down. There is a possibility too that it requires nothing more than a clip position change on the jet needle. Check with the dealer in your area to see what his recommendation is for jetting for that machine.
"Sled till you're dead"
retiredpop is offline
