Off-Road Forums & Discussion Groups - View Single Post - Lifts and plows...do they mix?
post #8 of (permalink) Old 12-13-2000, 04:04 PM
Re: Lifts and plows...do they mix?
I hate to snuff your lift dreams...It'd be easy enough to make some sorta butch solution to this problem. If you're only doing your drive and a few neighbors...you could just make a piece of metal that would fit between the top of the leaf springs and the bottom of the frame...held in place by sorta clamping around the leaf on bottom and maybe have one bolt holding it to the frame...this would prevent the springs from sagging at all...in other words, no front suspension movement when plowing. That wouldn't be all bad if you're not going to go down the road with it. You'd still have the rear suspension to accomadate uneven driveways and such.
Moneyless, Will weld for jeep accessories.
