Off-Road Forums & Discussion Groups - View Single Post - manifold still leaks
post #5 of (permalink) Old 12-10-2000, 09:23 AM
Re: manifold still leaks
I installed the entire gasket set! I torqued the end bolts down to 50 lbs, and left all others at 25. I was hoping that this will cure the problem, but now it is ticking when the engine is working, when I let the clutch out. If the engine is revved without driving the car it sounds ok! I am going to check the manifold to exhaust pipe bolts. The thing could have at least gone back as good as it did before i took it apart you know! Thanks for the help guys!
MULE
