Off-Road Forums & Discussion Groups - View Single Post - 1993 2wd to desert runner
post #7 of (permalink) Old 10-11-2000, 03:22 PM
Drew K1500
Re: 1993 2wd to desert runner
To install the new axle under your leaf springs should be a simple bolt on. As the only difference between the axles was that the 4x4 had their spring mount on top of the axle as where the 2wd has it on the bottom. You might even be able to use your original u bolts. The driveline extended a little but not enough for me to worry about it at all. I had limiting straps on my rear that would have prevented it from over extending anyhow.
