Off-Road Forums & Discussion Groups - View Single Post - Rancho shock part number
post #2 of (permalink) Old 09-13-2000, 07:52 AM
JEEPN
I Do This For The Glory
JEEPN's Avatar
Re: Rancho shock part number
Do a search on these, but I'll post anyway.
What I do, and it's never failed me, is take my own measurements. I measure the shock length at rest, then measure the space between the axle and bumpstop (or frame if you don't run bumpstops). Then subtract the axle to bumpstop distance from the shock length. This gives you the minimum shock distance you need, I usually subtract another 1/2" for good measure. Then I go to http://reality.sgi.com/rogerb/4x4/Rancho.html and look up the shock, with the right ends, that matches the "collapsed length" and find the longest one I can use. My older brother bought RS 9000's "for a 2.5" lift" and demolished them because his springs settled. I run a 5" lift and my springs are just right. It takes into account the sag and other lifts in combination. Let me know if I can be of further help and good luck.
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7" Lift/33" Swampers/REP 8000/RS9000's/Scout II D44's F&R w/4.10's & Lockrights
JEEPN is offline
