Off-Road Forums & Discussion Groups - View Single Post - Took the "new" CJ out for the 1st time...
post #5 of (permalink) Old 09-12-2000, 10:04 PM
Re: Took the \"new\" CJ out for the 1st time...
Dan, a TH350 that has just been rebuilt and has no fluid in it will hold 10-12+ quarts depending on the pan and converter. The fluid should be checked warm with the engine running in PARK. When you fill the trans for the first time it will only take 5-6qts, then you need to start the engine and add the rest. Also, the vacuum line does need to be connected for the trans to shift properly and at the right speed.
Marc
