Off-Road Forums & Discussion Groups - View Single Post - amc motor mount questions
post #7 of (permalink) Old 09-10-2000, 01:37 PM
Re: amc motor mount questions
One point to be aware of, is that the CJ mounts put the engine off set to the drivers' side about an inch and with a slight twist. SJs mount the engine centered. Carefull measurements of the Scout may reveal that SJ/J10-20 type frame and engine brackets will work better and are alot easier to find in a wrecking yard. The SJ/J10-20 engine block to mount brackets are the same as AMC V8 cars, also. (They probably came with your 360!)
Advance Adapters sells a universal AMC V8 mounting kit that uses XJ style engine mounts, they are of the weld in type. They can accomodate most frame widths as they have slots to allow side to side movement. Cost around $200.
Hope this helps, good luck!
