Off-Road Forums & Discussion Groups - View Single Post - Dp vs. vacuum carbs
post #10 of (permalink) Old 08-01-2000, 01:06 PM
chevota
Pooh-Bah
Re: Dp vs. vacuum carbs
tough-trucks
True, but the vacuum port is located a bit down the barrel past the venturi. It needs manifold vacuum or a serious amount of flow past the venturi to generate a significant vacuum to open the secondarys. In either condition the seconderies should have already have been engaged.
True, a Dbl will be down at wide open @ low R's, but that is its ONLY drawback, and it is easily cured with foot control. Also the secondaries have an enrichment circuit, and a power valve to help control fuel mixture at variable vacuum/rpm/opening rate conditions.
A vacuum carb relies on vacuum to control these conditions, an easy cure, but at a cost in power, especially accelerating.
Chevota
chevota is offline
