Off-Road Forums & Discussion Groups - View Single Post - '97 S10 Blazer running rough with codes
post #2 of (permalink) Old 05-11-2011, 03:38 PM
blowns10
Journeyman
MAF - you may want to check on the screen to make sure it's not clogged or dirty and clean it. I'm pretty certain that what you want is volts.
Misfire - could be worn/fouled plugs, bad wires/cap/rotor, low fuel pressure, bad injectors. Could be fuel (low fuel pressure) or ignition related (not enough spark created for complete combustion)
EVAP - the gas cap is the most common. If it doesn't fix it there's a black cyindrical shaped object, which should be near the bulkhead (firewall). Could be in need of replacement hoses or there may be a leak in the system.
I hear that the Haynes manual is much better and more detailed than the Chiltons; in comparison to the FSM which is about $115, it's your next best bet.
I need a bigger engine!
blowns10 is offline
